dryer runs allthe way through to off but continues to run ,buzzer sounds timer stops, heat is off , there is no power to timer motor but dryer continues to run?
i was given this part #ap278251 for model # admiral inc7745a71, my questin is the old timer has a rectangler , ceramic resister will i have to remove it and solder it to the new one, i just want to be sure i’ve got the right part.before iorder it.
thank you
herman
