About a week or so ago it stopped drying the clothes. Blower motor is working and l do feel heat, but the heat isn’t getting to the barrel.
Finton,
Have you checked your exhaust venting tube ,pipes and hood for blockage ?
Disconnect the vent from the back of the dryer, and run it for 20-30 minutes and see if it heats properly, that will help to confirm it.
Being a gas dryer you could also have an intermittent set of coils on the gas valve, or weak igniter.
You’ll need to remove the front panel of the dryer and observe the ignition procedure, to confirm that process.
