Dryer will not Start
I have a Frigidaire gleq942cs0 dryer. Everything has been going fine until today. control panel works fine when you select a cycle and press start you will here a click, like a relay pulling in, and nothing happens. The timer will continue to count down, but nothing happens in drum will not spin or anything. No humming to indicate a locked up motor, Drum spins freely.
I checked the 2 thermal cut switches and both are reading closed with wires disconnected. I have verified that I have 240 coming into the terminal block. L1-L2 240 and L1 -G = 120v L2-G =120v.
Thermister reads 47.3 at 65 to 70 degrees at body temp ( by holding finger over sensor) it drops to 37.0…
Any ideas? with motor free spinning I am hesitatant to replace without a definate diagnosis.
Sounds like a control Board problem is possible as well.
Let me know thoughts please.
[FONT=“Calibri”,“sans-serif”][COLOR=#000000]Figuredit out finally. Found a bad solder spot on the relay that activates the graywire that starts the motor, gives 120 to the motor and completes the circuit. Iclosed the gap and it runs like it’s supposed to. I have my soldering stuff atthe fire station so I will try and repair it tomorrow and then replace theboard if it does it again I will replace the control board.[/COLOR][/FONT]
