Dryer will not heat and the timer will not move
my dryer will not heat and the timer does not move, 3 hrs later my clothes were still wet and the timer never moved off the setting that i had put it on what could be wrong and what part(s) shoud i get
dryer will not heat and timer does not move
you need a heat element or a thermal the timer wont advance because it is thermastat controled and untill the thermastat opens it doesn’t put power to the timer motor
ok how will we know which one it is, the dryer still runs but blows all cold air..
