My husband thought it was the timer but he order and replaced the timer and my dryer still will not stop at the end of the cycle. The timer still run after the cyle said it should be off.
I have to unplug the dry from the wall to stop it. :mad: What part is needed
We seem to be missing the last digit of your model number. Please post it and we can probably come up with something.
[quote=joanne1987@sbcglobal.net;125224]My husband thought it was the timer but he order and replaced the timer and my dryer still will not stop at the end of the cycle. The timer still run after the cyle said it should be off.
I have to unplug the dry from the wall to stop it. :mad: What part is needed [/quote] Model kenmore gas dryer #110.97374210 Please help!!!
Hi Joanne
Try this replacing the push to start switch, here it is from APP but you can also get one from any appliance parts store.
Also, your dryer should stop when you open the door.
If this does not fix it, and it does not stop when you open the door then you may have some wiring issue which will have to be checked wire by wire.
Let us know what happens.
Thank You, Thank You, Thank You!!! I Took Your Advice And Purchase A Push In Starter And Put It In Myself…
It Work. Thanks Again For Your Help!!!![]()
Well great, nice going and thanks for updating us.
