Dryer very noisely
Kenmore dryer very noisy. Replaced rear drum rollers and idler pulley. If the motor shaft is rotated by hand, the motor shaft does not turn quietly.:confused:
[COLOR=“DarkRed”]If the motor shaft is rotated by hand, the motor shaft does not turn quietly.[/COLOR]
Then the motor is probably the cause of the noise.
