Dryer stopped mid cycle
My dryer stopped mid cycle, went I went to check my clothes the dryer was still warm and I could not get it to restart. someone told me it is probably the thermal fuses and it comes in a two part kit I found the larger one on top but cannot find the smaller one. Can you tell me where it might be?
I am not sure which ones you have found, but look inside the blower cover and on the heater. To get to the heater you may have to remove the belt and drum.
Here is a service manual for one that should be pretty close to what you have listed as your model number.
http://www.servicematters.com/maytag_library/docs/16026315.pdf
good luck
