Dryer starts to dry then stops
Whirlpool Ultimate Care II starts to dry then stops heating. I can watch the ignitor light the gas but then it doesn’t stay heated. Timer? Fuse?
Hi Bryan,
Most likely this problem caused by insufficient air flow.
Remove the rear panel and the lint chute (#1 on the bulkhead break down diagram). Clean the lint inside and check the blower wheel.
