Brand:amana Model Number:nde5800ayw Main Symptom:, Stops mid cycle, heat is working, heat may be to hot? What happens & when:dryer shuts off before timer ends every time
Error Code (if any):N/A
Parts or tests already tried: looking to replace possible high limit thermal fuse, or high limit thermostat, or cycling thermostat (5 prong switch and not 4 prong as shown in video)
They use the same video for both of them, but the 5-prong thermostat is WP37001136. The high limit thermostat is WPW10116735 and the fuse is WP40113801.
If it seems like it is getting too hot I’d also check that heater just to make sure it hasn’t grounded out.
