Dryer shuts off in middle of cycle feels like overheating
Brand: GE Hotpoint Dryer
Model Number: HTDX100em8ww
Main Symptom: Shuts down in middle of cycle
Error Code (if any): none
Parts or tests already tried: Completely cleaned lint inside and all tubes. Removed drum and cleaned out lint,
Photos / video link: none
If the dryer shuts down completely and has to cool down for a bit before it will restart, this is likely an issue with the motor overheating. Ensure the blower assembly and the vent is clear all the way to the out side and that the vent is correct size and material as well.
Yesterday I removed the drum and and completely cleaned out the inside and all of the tubing and chutes. It appeared to work a little better after that but it continues to shutdown in mid cycle. Think it might be the thermostat sensor but I am not sure
I sent a response about 5 hours ago When should I hear back from somesone
