I recently moved the dryer into the basement, got it hooked up and all was good for a few seconds. Then I heard a something from the fuse box and the power in the dryer went out completely. Found out the ground wire was bare and exposed-- apparently it shorted (the copper was nice and black) but didn’t trip the breaker.
Now nothing is working. Does anyone know if there is a fuse in this model or what i can try prior to calling a technician or what part I should test first?
i appreciate the tech sheet- they recommend replacing the machine control electronics- do you know if there is a way to test that part. Trial and error with electronics can get expensive.
