hello everyone,
Got my self a little problem with the dryer and need some advice.
My whirlpool dryer runs but the heat only stays on for about 5-10 minutes then no more heat (dryer still running). I have to turn my dial to off then on again (reset)for it to work again then same thing happens again and again. I have checked the ducts and everything seems clean and plenty of air flow. Im thinking it might be the gas valve coils or the thermostat.
Any suggestions? thanks
If you have a plastic button on the front panel, pull it off and check your flame. If it seems “normal” with the flame bluish, you probably have bad gas valve coils.
