dryer will not start. I have replaced the starter switch, the belt is still in good shape. any ideas?
Replacement parts for keys750j models | AppliancePartsPros.com
Here is the wiring diagram
http://www.servicematters.com/docs/wiring/Wiring%20Sheet%20-%203406699.pdf
I am assuming that the unit seems totally dead.
A multimeter will make troubleshooting this much easier.
First check that it is getting the correct power.
L1 to L2 should be 240 volts.
It is not uncommon to loose half the line without actually tripping a breaker.
You could try flipping the breaker off/on slowly a couple times.
Could be that the thermal fuse on the blower wheel (Item 6 in Section 3) has blown.
Unplug the unit and check the fuse with a meter should be 0 ohms.
Jiggery Pokery method is.
Unplug the unit.
Remove both wires from the fuse, short them together and tape them up so they will not short to the frame.
Plug the unit in and give it a try.
If blown, replace the fuse ASAP as it is a critical safety device re: prevents lint fires which can turn into house fires.
Also clean/check your vent system and the blower as these are the most common causes of it blowing.
