*Brand: Frigidaire
*Model Number:FAQE7072LR0
*Main Symptom:motor does not stop
*What happens & when:At the end of the program time indication disappeared on the screen, then popped up the error code E51 and came the alarm beep-sound
Error Code (if any): E51
Parts or tests already tried: I want to test the motor relay RL2, but don’t know wher it is located and how it looks like
Thank you for your question. On the main control board, located in the control panel, there will be a RL2, which will be connector J3 pin 2 and J3 pin 1. This is the location that you would check . If motor runs continuously with power applied check for short circuit across
motor relay (RL2), or L1 applied to motor relay output (J3-1) with cycle
stopped. If motor does not start when “start” key is pressed, check for open
circuit between L1 and motor relay connection (J3-2). If no wiring problems
found, replace Electronic Control Board.
Thank you very much for your quick help. Appreciate!
Yesterday I opened the main control board and could not find there a piece which looked like a relay, so I could not do the test J3-1 and J3-2 as you advise.
Then I was thinking where else the relay could be located. I concluded that a good chance could be somewhere near the transformer.
Today I began to search the transformer and found it quickly, above the drum on the right side, immediately below the top panel. Easy to find, easy to reach.
And yes, I saw a dark square piece right next to the transformer which could be the relay RL2.
I had heard that sometimes a relay gets stuck and that a few taps are enough to loosen it up again. So I gave that at first a try, before doing the check and it worked!
I lucky and my wife happy!
