My dryer was working fine then just quit. I check to make sure it has power and that the motor did not lock up. Everything seems fine. Not sure what I need to check next.
Unplug the dryer, and take the back panel off!! You will see a white part that is an inch and a half long, by a 1/2 in wide. That is the thermal fuse. That will be your problem. If you want to jump it out to check it, go for it. Tom ApplianceEducator.com
