Dryer Not Functioning
My Admiral LNC7764A71 was not working. I verified the power to the unit and verified the Thermal Fuse did not have continuity. I replaced both the Thermal Fuse and and High Limit and confirmed their continuity. The using still is not functioning and the interior light is not working. What is the next step to diagnose the problem?:confused:
Here are your parts includes a wiring diagram
Replacement parts for ADMIRAL LNC7764A71 DRYER- ELE | AppliancePartsPros.com
Next I would check the power and then the door switch.
Try flipping the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker.
L1 to L2 should be 240 volts
If OK
If OK
[COLOR=β€œRed”]Be careful as 240 volts is lethal !!! [/COLOR]
