Dryer not drying
At first drying took longer than normal. Now it does not heat at all. The digital display jumps from 1:36 to 1:52 then goes in a circle after a few minutes. Checked breaker and venting both ok. If heating element is bad should the thermostats and the thermistor also be replaced. Or should I call a repair man.
Here is the parts breakdown, includes a wiring diagram
Replacement parts for MAYTAG MDE2400AYW Dryer - Ele | AppliancePartsPros.com
I could not find a tech sheet for this unit
The following may help
http://www.servicematters.com/maytag_library/docs/16023432.pdf
http://www.servicematters.com/maytag_library/docs/IDL-0002A-B.pdf
http://www.servicematters.com/maytag_library/docs/TDL-0076A-B.pdf
http://www.servicematters.com/maytag_library/docs/ITDL-0037-B.pdf
[COLOR=“Blue”]Checked breaker and venting both ok.[/COLOR]
Did you actually measure the voltage?
[COLOR=“Blue”]If heating element is bad should the thermostats and the thermistor also be replaced.[/COLOR]
I would check them with a meter first.
[COLOR=“Blue”]
Or should I call a repair man.[/COLOR]
Depends on how handy you are !!
