Dryer noise
Hi first time here..My Dryer makes squeaking noises but till drys…How do I get in to check the drum bearings? Thanks
The top should come up if you pry it loose from the clips with a screw driver in the gap between the top and front near the edges. Take off the front and take off the service panel in back to release the belt.
You can now take out the drum and get to the tub bearing, this part here.
AP2142648
