Dryer No Heat
Electric Dryer recently tripped the circuit breaker while the dryer was running overnight. I reset the breaker and but the dryer doesn’t provide heat. Any thoughts?
[COLOR=#333333]The first thing to check would be the source voltage[/COLOR]
[COLOR=#333333]where the dryer cord connects to the terminal block.[/COLOR]
[COLOR=#333333] [/COLOR]
[COLOR=#333333]If all is ok there then I would want to be sure that[/COLOR]
[COLOR=#333333]240 Volts is getting to the Heating element.[/COLOR]
[COLOR=#333333]If is then the element is bad.[/COLOR]
[FONT=Times New Roman][SIZE=3][COLOR=#000000] [/COLOR][/SIZE][/FONT]
