Brand: Electrolux dryer Model number: EIMED60LT4 Main Symptom: air dry is fine. Any heat setting loud noises after 10 mins running. What happens & when:air dry is fine. Any heat setting loud noises after 10 mins running.
Error Code (if any):none
Parts or tests already tried: replaced 3 sensors, motor, greased wheels
If it will not upload the video or an audio file, we have a Reddit forum that can be used and it should allow the upload. Otherwise, a file link might work. Here is a link to our Reddit forum where I can be found. The username I would be found under is u/AppliancePro_William. https://www.reddit.com/r/AppliancePros/
It sounds like the dryer is making a vibrating noise. Are you able to tell if it sounds like it is coming from a specific area of the dryer such as the front, bottom, top, etc?
When the motor was replaced, was there anything that may have been slightly loose or did the heating element coils look like they might be sagging a little bit?
We replaced the heating element too. Pretty much everything but the control board and rollers which are both being shipped. Blower fan looked fine barely any lint but we vacuumed out.
