Dryer just buzzes when push start button like cycle is done
When I push the start button all it does is buzz and the buzzer light comes on. This happens no matter where the dial is turned to except for off. I have checked the thermal fuse. Not sure what it is don’t want to buy a timer if not it can’t return it.:frowning:
Disconnect the pink wire (PK) from your timer. Take a multi-meter and test from the pink wire (PK) spade on your timer to the black wire (BK) on your timer in timed dry mode. When you try to start it, if you see voltage then you will have a bad timer. If no voltage is present, then you have a bad motor. Hope this helps. Here is the part number for the timer.AP6007917
