Dryer heats intermittently
Somtimes the dryer heats up just fine other times it does’nt heat. What can it be.
P.S. this is a whirlpool made for Kirkland.
Hello,
Several things could cause this issue, check the thermostats for continuity, also check the venting make sure there are no obstruction in the vent line. Below is a video that explians how to test the components on the dryer.
Dryer : ApplianceRepairLesson.com
Is this video for a gas dryer?
