HOW MANY GLIDES DO I NEED ?AND DO I NEED THE FELT PADS
AND THE GLIDES? OR JUST THE FELT PADS OR JUST THE GLIDES?
is THS SS PART NUMBER FOR STAINLEESS STEEL ?
I ALSO WANT TO CHANGE THE BELT AND GET THE RIGHT ONE, THIS IS PRETTY COMMOM MAINTENENCE WHY CANT THE PART PEOPLE HELP ME?
Dear Rogerchamberlin,
Sorry so late in getting back to you
According to your model number LEA60AW the following parts are required if replacing all felts, glide and belt:
[AP3885583] Glide ( 2 each needed)
[AP4054017] Felt (2 each needed)
[AP174428] Belt
Usually its best to check and/or replace all of them since they are normal wear. You might also check the drum support rollers under the back of the drum part number [AP3453184] (2 each needed )
If you still require assistance please call me at 1-877-477-7278
