Dryer getting too hot
Where is the thermostat in dryer located?
Click on view your model number and go to view 6,
It is more likely your problem is some type of blockage in your venting system. (see other posts on excessive heat in the dryer). Before replacing a part, thoroughly clean out the venting system, particularly the area between the filter and the blower, and take the cover off the blower to clean that area. Make certain your blower is operating correctly.
Good luck and let us know how it turns out.
Seems the problem is fixed. Replaced the thermostat limit. Now seems to working okay.. Thanks for your reply!!
Glad to hear it, thanks for getting back to us
