Dryer drum will not turn on
PLEASE!!! I NEED HELP NOW!!!when I push the start button the dryer drum will not spin. The heater turns on but thats it, WHAT COULD IT BE??? HELP!!!
If the motor fails to run, it could be your thermal fuse mounted on the blower housing, a thin white item. If the heater comes on without the motor running, you probably have a bad motor centrifical switch.
Does the motor make any noise when you try to start it?
