I just moved, dryer worked perfectly, plugged it in at my new home, light inside comes on but dryer will not turn on???
Here are your parts, includes a wiring diagram.
Replacement parts for ADMIRAL ADE7005AYW | AppliancePartsPros.com
Manually hold the door switch closed and see if it will run.
Could be the door is not actuating the switch.
Do not run it too long like this as you can blow a thermal fuse.
I assume it never ran even for a short period at the new house.
Open it up and check out the wiring could be one has come off.
