Dryer blowing thermal fuses
Replaced the thermal fuse in the Whirlpool dryer, it worked for two drying cycles and now the dryer won’t heat up again. Will need to replace thermal fuse again but need to know what else I need to do to get the dryer drying again, and suggestions?
A model number may help others help you.
Was the thermal fuse on the heater assembly or on the blower wheel?
When you say no heat, is it just no heat or will the unit not start?
