Dryer would not start. Would get buzzing sound when pushing start button. Took front of dryer off. Observed drum turning slightly when holding in start button along with a burning smell. Then turned the drum by hand while holding the start button and the drum turned at its normal speed. Repeated sequence twice with same results.
After trying a third time, do not get a buzzing and does not turn, even slightly. I am assuming the motor is a gonner, but is there anything else that may now be bad?
[QUOTE=Paulie K;289475]Dryer would not start. Would get buzzing sound when pushing start button. Took front of dryer off. Observed drum turning slightly when holding in start button along with a burning smell. Then turned the drum by hand while holding the start button and the drum turned at its normal speed. Repeated sequence twice with same results.
After trying a third time, do not get a buzzing and does not turn, even slightly. I am assuming the motor is a gonner, but is there anything else that may now be bad?[/QUOTE]
No, that would be the motor. Tom Appliance Educator, Appliance Parts, Washer and Dryer Parts, Refridgerator and Freezer Parts, Stove and Oven Parts
