Driping Water Onto Shelves
What can be done about water dripping onto the shelves of the frig ? Does the frig just need to thaw out ?
Hi.
Most likely there is a frozen condensate drain.
Open the rear panel in the freezer and defrost the drain using the blow dryer, hot water and patience.
Thank you. Post the results.
Simon.
