Dishwasher is draining water from the tub all the time. Therefore. there isn’t enough water in the tub to supply the pump with enough water to wash the dishes. Arms are not moving. Please help. Float in the tub to prevent overflow seems to be working fine. Tub will not fill up.
make sure some part of the drain hose is as high as the top of the dishwasher…
Check your model #, it will not work. Pull your drain hose and verify it is pumping out while it is supposed to be washing. If so, you may have an electronic module problem.
