Drain Valve availability
It looks like the drain valve stem seal leaks when the solenoid activates. Is the drain valve available separately? Or does the seal repair kit also include a seal for the drain valve. I guess it might be the pump seal leaking. Have to tear it out to be sure.
Also, is the pump body etc available without the motor?
Jordan
[FONT=‘Times New Roman’][COLOR=#000000]You can replace the drain shaft seal. It is not that hard just remove the drain solenoid and the push nut and insert the new seal. You will probably have to replace the push nut because you will most likely damage it while removing it. This page may help GE Dishwasher Pump Leaking Repair Guide[/COLOR][/FONT]
