Drain Pump Will Not Turn Off
So I have A Frigidaire Model #FDHG2433KW1 that the drain pump runs continuously. I’ve tried to run a clean cycle and also cycled power off at the breaker a few times and nothing seams to turn it off. It only runs with the door closed but as soon as it is closed it runs until you open it back up. The dishwasher is only 1 1/2 old. Thanks for any help.
I cannot find any info on the given model number.
Please check it.
I tried at AppliancePartsPros and the Frigidaire site.
It does sound like the control board is toast.
