Drain motor will not drain water and also will not stop running/ or cycle to next function. Drain pump/motor will not stop running unless I turn off power from power button..
Any ideas on what could be my issue?
your issue might be the same as everyone else’s. Circuit board/control module. read other posts with Bosch DWs contunuing to run and being stuck in cycle. Check this out:
Bosch Dishwasher Drainage Problem Fixes
