I first noticed water on the kitchen floor and pulled the bottom cover off and ran the dishwasher through a drain cycle to observe where the water was coming from. The water is coming out of the hose where it connects to the outlet on the dishwasher. I have removed the hose several times and can find to hole in the hose at the connection . It appears to be coming out of the bottom of the hose at the connection.Can you help me?
remove hose again look to see if rubber washer is still inside of hose fitting,if it is check for damage, it may need replaced.if it is good try some plumbers thread tape around male threads on dishwasher outlet.
remove hose again check for rubber washer inside hose connection,if it is still there inspect for damage, if all ok try to add teflon thread tape around male threads of hose outlet and retighten hose
[QUOTE=terrywampler;346707]remove hose again check for rubber washer inside hose connection,if it is still there inspect for damage, if all ok try to add teflon thread tape around male threads of hose outlet and retighten hose[/QUOTE]
Thank you for your reply. The connection dose not have any threads. The rubber hose connects using a C-clamp and it connects to a plastic fitting which is slotted on top and bottom. I have inspectec the hose and cannot find any tears or punctures. The dishwasher is a Maytag. I have had the hose off several times and it still leaks. I have ordered a new hose, but I kinda doubt that is the problem.
