I can’t tell were the door switch (ap4114315) goes from the diagram?
TS,
The door switches and latch assembly are located inside the door assembly.
You will need to remove the inner door liner to access the switches and latch assembly.
Here’s some information that should help :
[FONT=Arial][SIZE=2][FONT=Arial][SIZE=2][LEFT]Removal of the Inner Door Panel will allow access to the
Microprocessor Board, Door Switches, Detergent / Rinse
Aid Dispenser, and Vent Assembly.[/LEFT]
[/SIZE][/FONT][/SIZE][/FONT][B][FONT=Arial][SIZE=2][FONT=Arial][SIZE=2][LEFT]Removal
- Disconnect power to the machine.[/LEFT]
[/B][/SIZE][/FONT][/SIZE][/FONT][FONT=Arial][SIZE=2][FONT=Arial][SIZE=2][LEFT]2. Open the Dishwasher door. - Remove the 11 Torx™ screws along the sides and top of the Inner Door Panel.
- Separate the Inner Door Panel from the Outer Door.
- Disconnect wires from the Vent and Dispenser Wax Motors before pulling the Inner Door Panel away from the Dishwasher.[/LEFT]
[FONT=Arial][LEFT]Door Latch & Switch Holder Assembly[/LEFT]
[/FONT][FONT=Arial][SIZE=2][FONT=Arial][SIZE=2][LEFT]Two Door Switches are used in the Latch Assembly. Both switches are normally CLOSED and will open only when engaged by the Door Latch mechanism. Each switch is in series with respect to L1 and neutral line operations.
Failure of either or both switches will result in rendering
the Dishwasher inoperative.[/LEFT]
[/SIZE][/FONT][/SIZE][/FONT][FONT=Arial][SIZE=2][FONT=Arial][SIZE=2]NOTE: [/SIZE][/FONT][/SIZE][/FONT][FONT=Arial][SIZE=3][FONT=Arial][SIZE=3]Door Switches require no field adjustment.[/SIZE][/FONT][/SIZE][/FONT]
[FONT=Arial][SIZE=3][FONT=Arial][SIZE=3][B][FONT=Arial][SIZE=2][FONT=Arial][SIZE=2][LEFT]Removal - Disconnect power to the machine.[/LEFT]
[/B][/SIZE][/FONT][/SIZE][/FONT][FONT=Arial][SIZE=2][FONT=Arial][SIZE=2][LEFT]2. Remove the Inner Door Panel. (See paragraph Inner Door Panel removal). - Lift Door Latch Assembly out.[/LEFT]
[/SIZE][/FONT][/SIZE][/FONT][B][FONT=Arial][SIZE=2][FONT=Arial][SIZE=2][LEFT]Switch Removal - Disconnect power to the machine.[/LEFT]
[/B][/SIZE][/FONT][/SIZE][/FONT][FONT=Arial][SIZE=2][FONT=Arial][SIZE=2][LEFT]2. Remove the Inner Door Panel. (See paragraph Inner Door Panel removal). - Remove Door Latch and Switch Holder Assembly.[/LEFT]
- Depress locking tabs and lift switch from holder.
Good Luck,
[/SIZE][/FONT][/SIZE][/FONT][/SIZE][/FONT][/SIZE][/FONT][/SIZE][/FONT][/SIZE][/FONT]
