Washer stopped working yesterday. Checked for faulty switches in handle assembly, they worked fine. Fuse in control panel not blown. Any suggestions?
Here your parts
Replacement parts for WHIRLPOOL DU1055XTSQ2 Undercounter Dishwasher | AppliancePartsPros.com
Here is the tech sheet
First I would check to see if the unit is getting power.
A year or so ago, had a run of units where they had bad connections in the wire nuts connecting the units to power.
