Does not drain
  1. Motor does not turn on. When cycling through various selection options and pressing corrospondng buttons, motor will not turn on. At the “pots/pans” option, you hear a motor hum but it will not start.
  2. About 2" of water is standing in base of dishwasher. Does not drain.
Suggestions would be appreciated.
Thanks,
[quote=bpd8523;292392]1) Motor does not turn on. When cycling through various selection options and pressing corrospondng buttons, motor will not turn on. At the “pots/pans” option, you hear a motor hum but it will not start.
  1. About 2" of water is standing in base of dishwasher. Does not drain.
Thanks,[/quote]
Bpd,
Sounds like a bad motor relay or motor, as best I can tell.
AP3154718
And the motor pump assembly has been discontinued by the manufacturer.
There’s not a lot of technical information, or parts for a unit this old,
But that’s where I’d start, were it me.
Good Luck,
