My dishwasher quit working a couple weeks ago after a brief power outage. I took apart inner door panel and disconnected all plugs to control panel for a day. Next day plugged all back in and started to work. Now I have the same problem again, tried doing same thing as before but no luck. I select cycle and close door and minutes of cycle flash, try pressing start but will not start. Tried to run “Manual function test” and “Field service test” but it will not perform tests. Does not matter which buttons you push it will not start cycle or tests. What could be the problem?
[QUOTE=gcooker;811272]My dishwasher quit working a couple weeks ago after a brief power outage. I took apart inner door panel and disconnected all plugs to control panel for a day. Next day plugged all back in and started to work. Now I have the same problem again, tried doing same thing as before but no luck. I select cycle and close door and minutes of cycle flash, try pressing start but will not start. Tried to run “Manual function test” and “Field service test” but it will not perform tests. Does not matter which buttons you push it will not start cycle or tests. What could be the problem?[/QUOTE]
Just in case: Does it run if you program it to star in a couple hours? If yes, you might have a fault start/cancel key - like in my case…
