Diswasher door gasket
I am experiencing a leak when dishwasher is running. It is coming from the bottom of the door. I think it may be the door gasket. I felt around at the bottom of door and found that the gasket, at the bottom of door in the middle, isn’t connected, there is about a 2 inch gap. My question is, should that be sealed all the way around or is there supposed to be a gap there? Thank you for any assisstance you have to offer.
Cameron
Most GE’s have the following installed in the gap
Part Search
Thank you very much. That makes sense, that is the exact size of the gap. Would I see a decent flowing leak if that is not in place? Just placed the order. Again, thanks for the great advice.
Cam
