Brand:
Model Number:
Main Symptom:
Parts or tests already tried: i have unplugged to reset and still didn’t work
Check at the bottom of the door and look for broken or loose wiring. If the wiring is good then you will want to test at the display board for 12 vdc getting to it. If there is voltage but will not light up then this will be a faulty display board that would need to be replaced.
