Dishwashwer won't start
The dishwasher won’t start. This is what I’ve tried so far:
  • All the buttons seem to work (light up when pressed), except the rinse cycle and the start button
  • The machine does drain when I hit the Cancel/Drain button
  • I ran the diagnostics test and the machine did respond
Based on what I’ve read here, it would appear to the be control panel. Am I right or there other possible issues? Is part AP3774265 correct for this machine?
Thanks in advance!
Hi.
Your assumption is correct.
You are missing a number at the end of the model.
What color is the panel?
Simon.
Simon,
The panel is black. I couldn’t find the actual numbers anywhere on the machine as indicated by APP’s directions. The numbers I provided are off the actual order/receipt when I purchased the machine. Anywhere else I should be looking to confirm the model before I order the control panel?
Thanks,
Van
Hi.
Here is your panel AP6008259
Good luck.
Simon.
