Purchased 09/2010- Heater Element Replaced ( Fried). Upon Replacement - The Clean Light blinks 7 times then pauses then 7times again & Again.When Selecting Control Panel Options - all the selection light BUT when you select the start Button _ Comes On Then Goes Off- NO Operation of diswaher. The Only operable selection is the Cancel/Drain -Two minutes then goes off.
