Dishwasher
How do you clean the ribbon cable?
Connector Cleaning / Checking
Unplug the unit
Open it up
Clean the edge connector.
The directions were consise and made me able to complete the process w/o damaging the unit. This was, however, not the problem as it turned out (it’s never this easy for me!) but I now have a clean connector ribbon! Thank you very much for your time. Franci
[quote=denman;528819]Connector Cleaning / Checking
Unplug the unit
Open it up
Reconnect everything and give it a try.[/quote]
