Dishwasher
DW stopped working and the “clean” light flashed 7 times, paused and then flashed 7 more, etc.,. When I pressed the “start/resume” it gave 3 rapid flashes. I discovered that the motor had a seized bearing so I ordered a new motor ($150.00). Insatlled the new motor but no joy…still getting same indications. Please help
Here is the tech sheet which should help
http://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%208572216.pdf
