This dishwasher fills with water but will not wash or drain. All lights on the control panel seem to be working properly. Any help will be greatly appreciated. We have to fix this ourselves by nessesity.
Open the control panel and check the control board for any burned spots.
Remove the toe panel and check for 120 VAC to the motor. Check the motor windings according to the wiring diagram.
Here are the breakdown diagrams and Replacement parts for MAYTAG MDB6100AWQ | AppliancePartsPros.com
Thank you for the tips Gene. The circuit board looks fine. No burned spors or missing solder. As for the motor, can you tell me which wires would carry the 115 volts to it. I have located a harness with the yellow, red, grey and blue wires on it but am not sure which leads to read.
