door leaking slightly at bottom right corner, leaves white powder stain on kitchen floor with radiant heat in cement.
i relaced door gasket and bottom corner inserts in the body i did not relace center piece in bottom of door
also dishes not always clean is there a check/drain valve in washer assy and where is it located
