I have a whirlpool dishwasher DU1050XTPQ1 Ser# FR4002655 that the clean light is flashing. How do you check the heater circuit? thanks
Model DU1050XTPQ1
Here is your tech sheet
https://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%208535451.pdf
Best to use a meter. Do the Heater first (10 to 30 ohms). If OK then the Hi Limit Thermostat (0 ohms). IF OK then check across them to see it they get power (120 volts) when they should.
If you do not have a meter I would suggest you purchase one. You can get a decent digital multimeter for under $20.00. You do not need fancy though it is nice if the leads are a couple feet long.
