Dishwasher
Dear Sir:
The above mentioned dishwasher fills, washs (never stops washing) but do not move on to the next cycle. I have replaced the solid state control panel; however, the same problem still exists.
What is my problem?
#Thank You,
Dave
Hi Dave,
Which part did you replace: the control panel or the control board? How did you find which part to replace?
Hi Gene,
First Thank You so very much for your reply-it is greatly appreciated.
The new installed part number is Maytag 99002823. I determined this part number because the machine was not advancing to the next cycle (from wash to pump-out). Becuase it is a solidstate timer this was the logical step.
As I said-this did not solve the problem-the machine just continues to wash-on and on and on and on.
Is there a way to reset the electronic control board (iniitialize the system)?
Your help and/or assistance will be greatly appreciated.
#Thank You,
Dave Hahn
Telephone 605-279-2666
Dave,
For how long time it was not advancing?
Your dishwasher has a temperature pauses a few times during a cycle while it’s heating water, and if incoming water is too cold (manufacturer recommended at least 120°F) - it could take a pretty long time. The normal cycle could run for more then 100 minutes and it has nothing to do with the dishwasher.
