Whirlpool Quiet II won’t start. Clean light flashes 7 times, pauses and repeats. I believe this indicates a problem with the heater circuit and/or heater element. How can I determine if it is the circuit or element? I am assuming these are 2 different things. The element seems easy to replace but cost of element is approx $80 and don’t want to replace it if that is not the problem.
[FONT=Helvetica][SIZE=2][FONT=Helvetica][SIZE=2][LEFT]A heater fault detection program has been added to the
electronic control to check for temperature rise and shut
down the dishwasher if a temperature rise is not detected.
The cycles have been modified to add 8 minutes 45
seconds of fixed heat at the beginning of the main wash.
The control looks for the temperatures at the thermistor to
increase 4 degrees with cooler (roughly <110° F) inlet water
and 2 degrees when there is hot (roughly >110° F) inlet
water. If the temperature rise is less than the criteria, then
the unit will drain and blink the clean light 7 times. The
detection will be ignored if the temperature is out of its
normal range, 64° - 160° F, or the door is opened during
the fixed heat.
Proper incoming water temperature should be between 120°
- 140° F.
Possible causes of insufficient temperature rise would
include wires off at the control, heating element, thermistor,
inlet valve, door switch, motor or capacitor, failure of any
of the above components or siphoning of the water during[/LEFT]
fill.
resolution: [FONT=Helvetica][SIZE=2][FONT=Helvetica][SIZE=2]
[LEFT]Once a heater fault is detected and the condition resolved
the electronic control must be reset by initiating a service
diagnostic cycle. [/SIZE][/FONT][/SIZE][/FONT][FONT=Helvetica-Bold][SIZE=2][FONT=Helvetica-Bold][SIZE=2][FONT=Times New Roman]NOTE: Using the RAPID ADVANCE[/FONT]
CYCLE will cause the blinking LED condition to reoccur
because there is insufficient time to heat the water.[/LEFT]
[/SIZE][/FONT][/SIZE][/FONT][FONT=Helvetica][SIZE=2][FONT=Helvetica][SIZE=2][LEFT]Check the product Tech Sheet for the correct cycle[/LEFT]
sequence.
Hope this helps,
Nat
[/SIZE][/FONT][/SIZE][/FONT][/SIZE][/FONT][/SIZE][/FONT]
