Dishwasher won't start
I have read other posts on this problem but can not access “initiate a service diagnostic cycle”. Where is this procedure found or do you have a copy?
Usually the technical documentation should be in the pouch behind the bottom panel.
If you can not find your tech sheet you could download it here.
GU2400 Tech Sheet
